Zf s6-40 6 speed
Car: 2000 firehawk
Engine: ls1
Transmission: 6 speed
Axle/Gears: 3.42 auburn
Zf s6-40 6 speed
what type of bellhousing would i need to run this behind my 74 350 block?
1 Post
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
If thats a corvette 6 speed just use a corvette bellhousing from 89 to 96. The other question is what flywheel to use with it. The ZFs use a two piece flywheel with a 3.00 inch bolt hole circle. Your 74 crank uses a 3.58 bolt hole circle.
