T-5 whine in reverse? loud!
Old 12-16-2004 | 12:24 PM
92heritageRS's Avatar
Car: 06 Trailblazer SS
Engine: 6.0 LS2
Axle/Gears: 4.10
I know some imports make that whine in reverse but is it normal for a t-5 in my 92 RS? The car has about 105,000 on the clock and has been doing it for as long as I can remember I just thought I would ask.
Old 12-16-2004 | 02:31 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Never seen the insides of a T-5, but typically, the reverse gears in transmissions are straight-cut rather than helical like the forward gears.
Straight-cut gears are noisy; in some transmissions more, some less.
Old 12-16-2004 | 02:49 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
They have straight cut teeth for the reverse, and they do make more noise, usually not an annoying amount though. if it's behaving properly, not jumping out of gear or anything like that and there isn't large quanties of steel in the fluid when you do changes you should be ok.
Old 12-16-2004 | 03:04 PM
Engine: 6.0 LS2
Axle/Gears: 4.10
Thanx just wanted to see if it was just my trans doing this.
Old 12-16-2004 | 03:21 PM
chevboy28's Avatar
Car: 1992 25th anniversary camaro
Engine: 406
Transmission: t56
Axle/Gears: 410s
my 92
does the exact same thing and has 48,000 miles on it.
Old 12-16-2004 | 06:40 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
That noise is exactly the reason for helical cut gears for the forward gears. Its nothing unusual. Many race cars have trans's with straight cut gears because they allow faster gear changes and they are stronger too (could be wrong about that one though), but the noise is just insane.
Old 12-16-2004 | 08:39 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
That's why the old M22 "Rock Crusher" 4-speed has a whine to it. The forward gears are cut at a smaller angle than "normal".
I think straight cut gear transmissions are stronger than helical cut gear transmissions because they tend to transmit loads the gears rather than the case.
Old 12-16-2004 | 10:10 PM
Air_Adam's Avatar
I forgot all about that untill you brought it up, but yes, thats exactly why they were so loud.
Contrary to popular beleif, the nickname "rock crusher" has NOTHING to do with the strength of the M22... it was the whinning sound it made
Old 12-16-2004 | 10:35 PM
custom88camaro's Avatar
Car: 88 camaro
Engine: carby 350
Transmission: t-5 from v6 car
My buddy Abe has a Jericho tranny in his 60 Impala. That bad boy is loud!!! I think it is worth the noise, tho, because he doesn't even have to lift to shift. He just holds it to the wood and pulls it into second. You should hear it when he tries to shift it slow just cruising tho. GRIND!!! NO synchros.
I like the "whine" I think it sounds kinda racey.
loud91rs
10-05-2015 11:05 PM
thejimsterz28
09-30-2015 09:52 PM
luvofjah
09-26-2015 09:28 PM
Youngs92
09-23-2015 12:29 PM
DARKmj16
09-09-2015 05:07 PM
Quick Reply: T-5 whine in reverse? loud!
