Torque Arm Bolt Size?
Car: 1992 Z28
What size socket is required to remove the torque arm bolts? 20~22MM? Will I need a deep socket or will a shallow work? Also, do you know what they need to be torqued back to?
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
shallow socket with an open end wrench. i put my bolts back in the opposite way so ta. can be removed without touching rear end. i just tightened mine with a 3/4 ratchet as tight as i could.
Car: 1992 Z28
Originally posted by 1982t-topTA
22MM, tight as you can get them
Car: Trans Am
ambainb
04-25-2016 09:21 PM
Thirdgen89GTA
08-20-2015 03:11 PM
