couple questions over t-5 swap
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
im currently swapping in a t-5 for my 700r4, unfortunatly last week i shattered a sunshell and some planetaries, so what better opportunity for a swap? anyways...i was wondering if anyone happened to know a part number on the connector i will need for the reverse switch on the tranny, also, for the TC lockup connector, do i just cut the connector off and connect the two wires?? also, the tranny im getting is out of a 91 z28, and my car is equiped with 2.73s, and correct me if im wrong, but the 91 z28 with the t-5 came with 3.08s?? so does this mean my speedo will be off? thanks in advance
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
The reverse connector is a regular 2-prong round-plug connector, you can find it at any stealership. Or junkyard if you have good ones in your area.
TC connector: leave it unplugged.
Yes, if you have 2.73's, you need a different VSS. I doubt your current VSS from the auto will fit in the T-5 anyway (mine didn't). If you need any more help with sensor and gear part numbers, lemme know.
Good luck, it's a fun swap.
Lou
In Edit: I assume you know what to do with the 6 shifter switch wires?
Lou
Car: 92 rs camaro
Engine: 305 lo3
yah i know what to do with those. i was reading you have to jump the lock up wires?? it seems like an easy swap, gettin the 700 out was a bitch though. what do i need to do about the vss if it won't fit in the t-5?, am i gonna have to buy one that will?
Engine: TPI
I never read anything about the TC lockup wires having to be jumped. I left the whole 4-pin plug disconnected and it's working fine.
The auto VSS is in most cases the big one - almost 2" in diameter - (see pic) and the T-5 VSS is usually the small one - under 1" in diameter - (see pic). I am referring to the diameter of the hole, not the metal body of the sensor.
If you have your T-5 close by, measure the diameter of the hole in the tailhousing where the VSS goes. You can find the VSS at a dealership (part # 10456087) for under a hundred bucks. If you have a friend there, it might cost you only $50. Advance Auto Parts sell them for cca $80, NAPA would charge you around $75. AutoZone does not carry these.
You will also need the right gear for the sensor. Depending on your tire size, axle ratio and drive gear teeth, you can calculate what you need:
Tires: 245/50R16
AR (axle ratio): 2.73
T1 (teeth #1): 9 (red gear)
TD (tire diameter): 25.65"
TRPM (tire revolutions per minute): 20168 / TD = 786.28
T2 (teeth #2): T1 * AR * TRPM / 1001 = 19.30
So you might need a 19-tooth driven gear. But that depends on the DRIVE gear in the tailhousing. Check the number of teeth on it.
The driven gears for a T-5 speed sensor cost about $22 nowadays (yeah, talk about *******s trying to rip people off for a piece of plastic - the auto VSS gears cost $3) and can be obtained only at the dealer. I'll try to get the part number for ya.
Lou
Tires: 245/50R16
Lou
Car: 92 rs camaro
Engine: 305 lo3
thanks for all your help lou, everyone says the swap is fairly easy...whats your scoop? so far i have removed the brake pedal, shifter, and removed the 700... which is a pain when your working alone, now i just have to wait for my t-5 and change over accessories from hawks. everything from now on seems easy. what gears do you have out back?
Car: 87 IROC
Engine: mini-rammed 350
Transmission: WC T-5
I have 3:73's behind my T-5...makes for a FUN cruiser...and it still only mopes along at highway speeds too
If your changing go at least 3:42,just my opinion
Good luck,you have the hardest part done
Getting that 700R4 out!
Later
Steve
Later
Steve
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally posted by 92rsbowtie
sweet, ever since i got my car ive always wished it was a five speed, so im pretty excited
Car: 1987 Firebird converted to 91/92 Trans AM appearance.
Engine: 2.8 v6 w/ injector, throttle body, intake mods
Transmission: automatic soon to be swapped out for a T5
Express autoparts.com is listing 4 different VSS for 1992 ranging in price from $34 to $70. The one I needed for my 87 wound up being the $35 one. The spendier ones were for Automatics.
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
im going to be doing the same exact swap over this winter along with fixing my front end damage... lol.... after replaceing my 700r4 with another one durrign the summer i dont think its hard at all to take one out and put another auto in.... i had to do it like 3 times to do stupid little things to my other 700r4 that was getting put in ... so now i can prollly do it with my eyes closed lol,,,, it wasnt realy hard ata ll just time comsuming thats the most parts....
Engine: TPI
If you have a part #, that would help the most.
Lou
Engine: TPI
92rsbowtie, I forgot to mention one thing. When you're stabbing the T-5 and it won't go all the way up into the tunnel ... you're probably doing the same thing as I did. I didn't know the bellhousing would have to be taken off the tranny and put on the engine block first. Never had to do it on my truck that way so it wasn't common knowledge for me.
So just to save you some time (if you already don't know it): you gotta put the bellhousing on the engine first and then stab the T-5 body into it. Otherwise you're risking hours of frustration.
Lou
Lou
Car: 92 rs camaro
Engine: 305 lo3
yah thats what ive read somewhere, it would be a lot easier anyways to get to the bell housing to block bolts with the tranny detached
The VSS I got from expressautoparts.com was the SC7 for 34.95 The other two they listed for 1987 were RPO D9A and D9B(the D9B being the one that came in my automatic from the factory) I think one of them was SC5(D9B) which was like $80.
The only way I found out which one was the right one was I went to the local parts house and had them look it up in a book. They listed the SC5, SC7, etc and had pictures. The SC7 was the smaller T5 type while the others were too big to be the right ones. It just so happens that Express autoparts.com listed the VSS by the same number that was in the book.(SC7) I hope to heck it is the right one or I don't know what I am going to do.
84z96L31vortec
08-10-2015 08:27 PM
