World calss t-5 owners
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
to those of you that have world class t-5s in your cars those only came in mustangs correct? if so how do you mount the transmission up to the torque arm and what are the torque handling specs on them?
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Re: World calss t-5 owners
Car: 87 Formula
Engine: 350 tpi
hmmm never seen them sold anywhere for camaros any ideas where i could get my hands on 1?
also itsa direct bolt inf rom a non w/c t5 right
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
I belive 89 was the first year they started to put them in our cars, u can tell them apart by the drain and fill plugs, world class has a allen key plug, there barley better then the normal t-5's, if your make any power and use it often either will last to long with sticky tires... but they are fun and pretty easy to fix...
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
1988 is the first year the World Class T5 was used in our f-bodies.
No there arent any aftermarket T5's for our cars like there are for Mustangs.
The closest replacement is the Tremec T5, which can be made for both an f-body and a mustang.
Yes, a world class T5 from a 88-92 V8 f-body is a direct replacement for a non-world class T5 from a 83-87 V8 f-body.
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
The World Class T5 has been in automobiles since 1985. Early non World Class 5 speed actually started finding themselves in autos in early 1983. Unlike the 6 speed Richmond Gear transmission this box was never designed around or based on American muscle car needs. The term "World Class" refers to a "World Class standard". What is this standard? Prior to this transmission's design no American car had a gearbox that felt and shifted like European and Japanese 4 and 5 speeds. The Richmond 6 speed is noisy and hard shifting because it uses the same basic synchro rings used in 1957 Borg Warner T-10 4 speeds. The World Class box allowed our muscle cars to shift like BMW's or 300ZX's. The concept was never intended for drag racing but for comfortable road touring. Carbon Fiber synchro rings, tapered bearings, and rollerized gears. Since engines took on fuel injection and lower torque bands they could easily handle the 3.35 or 2.95 1st gear ratios and enjoy the .68 and .73 overdrive. Borg Warner's mistake was that they underestimated American muscle car mentality and before they new it people were trashing these 5 speeds at the drag strip
Car: 83Z28 HO
Transmission: G Force 5 speed
Originally posted by Jacobs454
Tremec vs. BW = which is better?? Where do you get a Tremec and what's the goin rate? THANX!
Tremec vs NWC T-5 - Tremec again
-If you're handy with tools, you can upgrade a WC T-5 to handle power, for about 1.5K...
Or - You can buy a Tremec for a bit over 2K
Or - You can get a T56 which won't handle quite as much as the two above, but still more than any stock T-5.
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
http://www.g-forcetransmissions.com/default.htm
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Yea but for that kind of cash why not spend the extra dough and fork it up for a T-56. They can handle tremendous amounts of abuse and you get the extra overdrive gear.
Car: 83Z28 HO
But you can get optional gearing on the T-5 upgade so that 5th gear is a .59 ratio vice the .76 (i think) ratio the stock trans had. But the first four are stock ratio's. That's what I opted for on mine.
You just have to get used to winding 4th out a bit longer than the first 3!! lol
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
Or you can get a WC T5 rebuilt and upgraded at the same time to handle 400-450 hp/ft. lbs. for about $700--without all the clutch hassle of putting in a T56--saves at least a grand for gas and burgers.
Car: White KSwisses
Engine: 5.3L Gen III
Originally posted by JAYDUBB
What do you mean by no aftermarket T5's for our cars? What about G-Force? You will spend about the same amount of $$$ going to a Tremec.
They dont even reply to questions.
Damon
09-26-2015 05:29 PM
