"gov-loc" posi
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
"gov-loc" posi
Are gov-loc posi units any good?, i've heard a few horror stories about them.
A slightly used torsen 28spline posi from a '99 LS1 or an also slightly used posi-trac diff from a '95 LT1, which is a better buy? or are they pretty much equal?
Car: 87 Iroc Z28
Engine: 355 TPI
What exacly is so bad about the gov loc ? I have one in my truck and it works great, far better than any posi truck Ive ever owned or driven.
About the only problem I could see is things get kinda wierd when you get the tires spinning very fast, like when you gun it from a stop in the rain, when it starts to grab theres some pretty violent power transfer from right to left.
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Yea, that violent power transfer sucks. I've got an 02 silverado with that diff, I don't like it.
Car: 87 Iroc Z28
Engine: 355 TPI
Well it only really does it if you keep it to the floor when you got them spinnning really good. If you back off a little its not bad at all.
I guess for racing I would think it wouldn't be to bad being that your not really trying to spin the tires at that track, you want them to grab.
On a side not, the gov loc is also great for burnouts and donuts
Nice example I did a few months ago http://brewcitymuscle.com/~ponykiller87/
Car: 4
Engine: 6
Transmission: 5
The way they work, is that they act like an open, until the RPM difference between the 2 axles exceeds something like 100 RPM; at which point the little governor thing in them makes them lock up. So, they always act like an open from a stop, and don't "switch" to lock-up until after tire spin has already occurred. They're made for use off-road, in traction-challenged places, like mud. They grenade when they lock up suddenly on pavement. The parts are small and weak, simply not up to the task of hooking up high power and sticky tires with traction.
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
funny, it seems most new GM trucks use this rear, my TB does. I can spin 1 tire in the rain while turning but not in a strait line. Seems good for bad weather driving. My brothers 84 camaro had one and was very good in bad weather where my 9 bolt is always wagging around. I liked the way it drove in the camaro, seemed like a more refined traction aid for daily driving. i agree that it doesn't make much sense for a performance car but it did work well.
Car: 87 Iroc Z28
Engine: 355 TPI
I agree, it may not be designed to handle racing or the kind of launch that our cars would get out of it, but it sure seems to work good in the truck. Its been handling the abuse that I throw at it for the last 90,000 miles (up to 155,000 total now) and when I say abuse, I mean Offroad, onroad things that most people wouldnt imagine doing to a truck. I dont think I would ever put one in my car but if the one in the truck breaks I will deffinatly put another back in.
1 Post
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
Try this next time you're at the drags, get the car straight, do a little chirpy and pull the car straight into the beams (straight is the operative word here). We used to do this with the Detroit Lockers back in the 70's and it worked well. Whether or not a gov-lok is a POS or not I don't know.
These guys would...
http://reiderracing.com/differentials.htm
These guys would...
KO1
16
10-15-2015 05:00 PM
