Vibration at high RPM...
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I seriously doubt it's a motor thing. Even though it only happens at high rpm (above 5k). My guess is the pilot bearing. Any way to test it w/o pulling the tranny, again.
Thanks.
Thanks.
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
You sure it's drivetrain related?? Could it be an out of balance tire?? Maybe driveshaft?? Do you notice any difference when the tranny is shifing gears or going into overdrive?? oops sorry just read it again...must be a manual trans!!
Engine: 355
Axle/Gears: 4.11
The trans is a retrofit T-56 w/ a stage 5 spec clutch. I'm thinking I may have damaged the pilot bearing. The tranny didn't slide in perfect and I used the bolts to draw it up to the motor.
When I jack the car up and put it in gear, the rear tires still turn even w/ the cluch in. It's a new clutch, and thow out bearing. The tires turn slowly, but they still turn.
The car is also a little hard to shift.
Car: 91 Camaro RS
Engine: 305 TBI
you may have damaged something. Never draw the trans up to the block by tightening the bolts. Trans should beable to be pushed up against the block by hand.
Engine: 355
Axle/Gears: 4.11
