T-56 Leaking from rear?
Old 10-01-2004 | 06:55 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
I just finished installing my T56....I have the shifter off so I could pour the tranny fluid through there. There is a hole about 1/2 inch in diameter looking straight down. As I was pouring the fluid in, I could hear it quickly hitting the floor underneath, crawled under the car, and saw it was leaking at the tailshaft of the tranny. Im assuming its the rear seal.....is there anything else it could be?
Old 10-01-2004 | 07:00 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
try and see if it is comming from where the drive shaft goes in or if it is comming from a hole like where the speed sensor goes or even if the rev. lockout is not fully seated in the hole (check the o-rings on the sensor and the lockout too.) those are all in the rear tail housing
Old 10-01-2004 | 08:45 PM
mult68's Avatar
Engine: 305 TBI
it is definetly coming out and over the black seal around the tail shaft....right where the driveshaft yoke would slip in.
Old 10-01-2004 | 08:53 PM
Engine: ls1, LB9
well, that is the seal. I belive it is all one piece:shrug: but, if it is leaking that fast it is not in all the way or has a good rip in it
Old 10-03-2004 | 12:02 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
put the driveshaft in.
Old 10-03-2004 | 08:18 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
If the driveshaft yoke isn't in there's nothing for the seal to seal against. Follow JMD's advice.
Old 10-03-2004 | 08:23 PM
mult68's Avatar
Engine: 305 TBI
yes it was just the seal. I snapped my old driveshaft so I had just the yoke in the tranny. The old seal had sort of a dust cover looking thing on it....the new one does not...this shouldnt matter right?
Old 10-03-2004 | 08:31 PM
jmd's Avatar
jmd
the chrysler style "foreskin" seal came factory in the T56. The flat GM seal works fine too.
Old 10-03-2004 | 09:17 PM
mult68's Avatar
Engine: 305 TBI
heh.....foreskin
Exxon Limited
Camaros Wanted
22
12-21-2015 11:36 PM
wayshegoes
08-17-2015 01:00 PM
86White_T/A305
08-17-2015 01:16 AM
Exxon Limited
08-09-2015 09:13 PM
cRoe4
08-07-2015 09:46 PM
