TV Exh Check Ball
Car: 92 Z71
Engine: 350 TBI
TV Exh Check Ball
Is it common to leave out the TV exh check ball on a 700 ? Some sources seem to say to leave it out, though I'm not sure of the reason. The ATSG manual does not mention anything about it.
It is the one larger ball (5/16" I think)
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
I recently read a few threads about it too, since I just put a trans go kit in and it didn't mention it. I left mine in.
Basically from what I've read, it's the failsafe incase the TV cable snaps - it'll force full line pressure at all times. Most people will say it's OK to leave it out.
I haven't noticed any problems with it in, and many people haven't noticed problems with it out, so it's up to you.
Car: 92 Z71
Engine: 350 TBI
well in that case I'd just as soon leave it in, better to be stuck with full line pressure than low line pressure in the event of cable snapping.
So what would be the advantage of leaving it out ??
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
