im f*ucked ill PAY someone to help with t-56 install
Old 09-30-2004, 08:53 AM
  #51
cgb
cgb's Avatar
Don't take this the wrong way....as I KNOW personally how frustrating almost any project on a vehicle can become..but if you get this frustrated on your own vehicle...beware of wrenchin' for a livin'... cause it can get ALOT worse..
As for the swap....I've done several auto to 5 speed swaps in 3rd Gen's....and most of them took longer than one day only because time constraints or running back and forth to get parts I'd forgotten.
As for lining up the transmission...if you've used the clutch alignment tool, and that part is done...try this..
With ALL four corners of the car on jackstands, as high and as even as you can get it, get the tranny up on the jack...
Now borrow another jack and use a block of wood between it and the oil pan on the engine...slowly jack the engine up until it's level again, as the engine tilts to the rear when you remove the tranny... it'll make getting the tranny in MUCH easier, it shouldn't need to be forced.
ALSO...if you seem to have it almost all the way in, but can't get the last little bit, make sure all your clutch hydraulics are hooked up, and have someone push the clutch pedal in while you're underneath sliding the tranny in...this can help get it in the last little bit.
AS for cutting the floor for the shifter...
Measure from the the front of the bellhousing to the front of the shifter on the tranny itself. Now measure this off under the car, and make a mark w/ a punch or knock a small hole in the tranny tunnel.
Now measure how big of a hole you need to make. Then drill a few holes right in line with the punch mark you made in the tranny tunnel, then just get some tin snips and cut it out....it's very easy with some decent tin snips.
As for mounting the pedals, master cylinder...what I do is swap to the manual pedals...and I use the braces on the pedal that hold the U bolt as a guide...and drill through the holes in the braces to make the holes in the firewall....once the pedals are in you'll also see where the hole is needed for the master cylinder / pushrod...I used a 1.5" holesaw attachment on a drill and never had an alignment problem.
Old 10-03-2004, 08:47 AM
  #52
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Originally posted by porkyzilla
**** i wsa going to pay a mechanic to do it for me ****in shady ******* i am going to cal the california bar assoc if my pilot bearing or input shaft is bent he dropped it and hella **** i kick him out of my house and iddnt pay him anything... right now the tranny is so close sitting on a jackr ight now... i didnt remove the shifter but my dremmel cant get int here tin snips suck...any other methods people used??? the bellhousing is on the engine right now
huh? so this guy drop your trans?
Old 10-03-2004, 02:52 PM
  #53
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
so many times...than he hammerd on it...i got angry and kicked him out....and didnt pay him
Old 10-03-2004, 03:11 PM
  #54
Engine: ls1, LB9
ouch!
Old 10-22-2004, 11:11 PM
  #55
dmb91rs's Avatar
Car: 91 Rs Convertible
Engine: 383, Holley Stealth Ram
Just completed the swap myself (yes all by myself, from start to clutch to transmission in and moving the car). Car runs awesome. Just trying to fix the speedo with the Dakota box. I live in San Diego...let me know! The only small problem I have is the clutch seems to push the fork and throwout bearing too far and slighty rubs when pedal is fully depressed.
Old 10-23-2004, 03:33 AM
  #56
porkyzilla's Avatar
Engine: 5.7tpi 350,
back from the dead ok might as well update...
ok just got done workin on it actually its so close i can smell it...i got to finish bolting up the steering column...and bolt the spohn torque arm to the rear...put in the batter, bleed all 4 brakes and shes done... those pedals are such a bitch omg...and the master u bolt holes were way off the first time i drilled them so i had to redill those, and i dont know how many times i ended up taking out and putting back in those 4gen pedals..but all in all a hudge pain in the ***..
ive run into nothing but problems every part of the swap...sheesh...
is anyones reverse hard to get to?? mine i have to push the console to get it to go in
Old 10-23-2004, 03:55 AM
  #57
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
That's the reverse lockout noid. There's a connector on the rear portion of the tranny (driver side) right next to the shifter face the front of the car. If you power that, it'll go into reverse easier. Wire that up to you brake light switch if you like.
Old 10-24-2004, 01:04 AM
  #58
porkyzilla's Avatar
Engine: 5.7tpi 350,
no im talking about in terms of the actual position of the reverse my console has to be flexed to go in...havent gotten it in yet...and they said there is no male connector at the dealership i dont have one...
Old 10-24-2004, 03:02 AM
  #59
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
That's sh*tty about the console thing. Do you have the auto shift plate in the car?
As far as the no male connector thing, mine didn't even come with a female connector; it was all busted up and broken off. I just epoxied the whole top closed with wires soldered in there. Works for me now...
Old 10-25-2004, 04:07 AM
  #60
porkyzilla's Avatar
Engine: 5.7tpi 350,
i havent tried it with the plate in there but right now its hard to get to
as far as the reverse lock out can someone show me a picture of the connector and where it is on the trans
Old 10-25-2004, 06:56 AM
  #61
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
Here ya go!
Attached Thumbnails im f*ucked ill PAY someone to help with t-56 install-1.jpg
Old 10-25-2004, 04:55 PM
  #62
porkyzilla's Avatar
Engine: 5.7tpi 350,
can anyone take a picture of their connectors for the back up lights...and the reverse lock out??
Old 11-29-2004, 04:23 PM
  #63
mhaskell's Avatar
How is this going? If i was on the same coast i would help you out.
I did the swap in one night, 12-13 hours total, its not impossible.
Old 11-29-2004, 07:21 PM
  #64
porkyzilla's Avatar
Engine: 5.7tpi 350,
well i know why now that it was such a pain in the *** to install and why it wouldnt go and why the clutch was so difficult well
they sent me a v6flywheel i took it to a shop after it wouldnt go into gear so it ruined my clutch....oh well im laughing now all that bitchin and complainin and it was only the wrong flywheel....
Old 11-29-2004, 09:22 PM
  #65
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
You will soon be the ultimate T56 swap authority.
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
Hello, Michael
08-20-2015 03:19 PM
kyleb24
08-15-2015 08:24 AM
cRoe4
08-07-2015 08:46 PM
Quick Reply: im f*ucked ill PAY someone to help with t-56 install
