Anybody know where to get "transmission stand"
Car: 83 T-top T/A, 92 RS
Engine: 1970 LT1,305 TBI
Transmission: Th-400, 700r4
Axle/Gears: 3.42,2.73
Just use longer bolts and nuts and mount it on the stand that is what I do. Havent had a problem yet.
I'm looking for the kind that looks like a C-clamp. That way you can install the output shaft and clutch packs with the trans vertical. I used to use a bench with a hole cut in it. Like the one below, but hopefully cheaper (this one costs $169).
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Well, its definately not as cool as that stand, but it is cheap. I use a 4wd extension housing so the tranny can sit flat on the floor. Granted you have to use a couple blocks of wood once you get the output shaft in, but it works. You do have to be careful not to knock it over though...
Hotrodboba400
12-10-2019 07:07 PM
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
TX-SleeperC5
09-24-2015 03:13 PM
