PArts for th350 swap
Car: 1984 5.7L Z28 H.O.
Engine: 4-Bolt 350 5.7L Carb
Transmission: 700R
i know i need a torqe arm conversion and a new driveshaft to go from a 700r4 to a turbo 350, my question is where can i get the torqe arm conversion kit,and what type of driveshaft do i need?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
B&M and Hurst make the conversion kit, you can get them at Summit racing or Jegs ... or have it ordered at a local shop.
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
If you have a 9" tailshaft TH350, you can reuse your driveshaft from your 700R4.
If you have a 6" tailshaft TH350, you need a driveshaft from an 82 (or some 83) cars with a 200C tranny, or lengthen your existing driveshaft.
Car: 86 BIRD
Transmission: TH350
ABOUT THE SPACER TH350 WITH A 700R4 TAIL HOUSING : I talked to a guy at Aamco to today. He said he has done this kit years before but did not remember the manufactor. He has a book on the kit in his tool box and said i could have it since he no longer needs it. I will go by on Manday to get it and will post all the info.
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
I know of two torque arm conversion kits. Hurst or B&M.
B&M is available through Summit. I think I got my Hurst kit directly from Hurst though a local parts guy.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
me and ljnowell will have the spacer part number available on wednesday night and can post it for you if you are interested in it ...
