Rear end noise under accel and decel but why???
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
The rear is pretty quite when the car is in nuetral but as soon as you put it in gear and give it some gas it makes a ticking kinda clunking grinding noise thats not all that loud but sounds horrable. I was thinking it was the pinion nut but from what I am reading on here that only makes noise on decel or when coasting and thats when mine makes the least noise? what else could it be. Keep in mind I have not yet checked the bolt so It could be that but I am wondering what else to look for while I am under the car so I am not just wasting my time.
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
when i had something sounding like that it was a couple teeth off the pinion drove fine but the more i drove worse it got it wasnt loud but sounded horrible good luck
Car: '82 Z28
Block the front wheels, jack up the back of the car, set it on stands, undo the bolts for the rear cover, pry it off and make a mess. Once you're in there, just check to see if all the teeth are normal looking and not chipped, broken or missing. Might be an idea to check your u-joints before doing that though. Make sure they're not flopping around. btw, still living in Chico?
Car: 92 camaro Rs
Engine: 305 tpi
yea Im still in chico and trying to work on two cars in the parking lot for my apartments and its geting really old. I went throught it and the u j's are fine then I open the diff and omfg like two or three teeth are missing from the pinion gear and a couple from the ring gear. that rear end is done. I guess its time for me to do the fourth gen swap but at least ill have better gears. posi, and disc breaks out back and you cant beat that.
Car: '82 Z28
I've got my old rear sitting around that has 3.42 gears, non posi and drums. Check over at Chico Auto Dismantling for a 4th gen rear, they might have something there for a fair price.
Car: 92 camaro Rs
Engine: 305 tpi
yea, I am looking to pick one up down there they have one chillin waitin for me but I got no way to get it home. it was a good price too. U get parts from down there cause the pull your self side of the yard is picked through./
Car: '82 Z28
I got the rear that is sitting on the ground now from them like 3 years ago now. That's the only part I've gotten but a buddy of mine gets stuff there from time to time, full service though.
hectre13
12-11-2023 09:14 AM
hectre13
08-26-2015 09:17 AM
AkDrifted
08-17-2015 08:45 PM
