700r4 cooling line size
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
I need some help. I want to replumb all of the cooling lines from the tranny to the Perma cool external cooler to the rad. tranny cooler with rubber hose and eliminate the hard lines.
Can anybody tell me the correct size and type of fitting to the 700r4 tranny and the correct size and type of fitting to the radiator tranny cooler connections!
THANKS!
Craig
THANKS!
Craig
Car: 1989 IROC Z-28
Originally posted by Apeiron
5/16" inverted flare.
Car: 1989 IROC Z-28
Thanks!--that made this project much easier to work with!
The lines to the rad were non existant when I purchased the car--been just running through the VERY LARGE Perma cool external cooler, which is why I did not have a "point of refrence" to start from.
Now i just have to locate some "hose barb" fittings that size--guess I'll start with Summit unless anybody has a better suggestion.
For the rubber tubing, should I just use gas line hose, or is there a better hose (without getting into the braidded steel tubing--money I do not have!)
THANKS,
CRAIG
THANKS,
CRAIG
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You should be able to find something at a parts store or industrial supplier near you that carries Weatherhead fittings. If not I believe a Permacool 15165 will work.
toronto formula
11-10-2015 07:17 AM
knight72
08-10-2015 10:32 PM
