tranny leak
Car: 84 z28
tranny leak
i have a 400r4 tranny. It leaks a drop or 2 when its just sittin but it leaks more when it is running. I know its not leakin from the pan seal (i replaced that and torqued eveything down) does anyone know where it could be leakin from?
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
you must be able to see where its coming from.if not get some varsol or some kind of cleaner and spray the transmission down and try to clean it up. drive it then look around for fluid,id be looking at the front seal where the toqure converter goes in to the transsmission or the tailshaft seal where the driveshaft goes in, maybe even where the speedo gear is...try it
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
