ZF 6-speed
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
ZF 6-speed
I was just wondering why people dont swap ZF 6-speeds into there cars? iv seen them on 89-92 TPI corvettes and some ZR1's. is there a reason why people dont use this transmission, sorry i dont know alot about these but i was wondering if someone did, i know they probably dont have the torque arm bar mount but besides that whats different?
1 Post
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
The T-56 swap is a lot easier to install and are cheaper. I always liked the ZF but it's a lot of work. You will need to fabricate a cross member and a torque arm mount. Also the ZF will hit the console in 1'st gear so you will need to fabricate a custom center console.
Car: 85 Camaro Z-28
Engine: 6.6
that doesnt actually seem like alot of work, you can always get a torque arm relocation kit and the consol, thats not a major job, but what about flywheels, clutch hydraulics ect? are all of that different or different then the 5-speed clutch setups....
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Do a search for ZBRA...he used to have a sweet Z28 with a ZF 6 speed he installed.
It's definitely not as easy as putting in a T56.
Car: Camaro
Engine: 6.2L
Another nasty issue with the ZF is they use a bolt on yoke not a slip yoke and there is only a couple of inches of spline so using one with a slip yoke is precarious to say the least.
1 Post
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
I installed a ZF in a 64 nova behind a big block 402 a few years ago and just recently began driving it on a regular basis. The ZF has a tendency to knock like an engine bearing about to launch through the oil pan. If you dont use the corvette dual mass flywheel they have the knocking noise. The noise isnt supposed to hurt anything but it is annoying idling below 1000 rpms.
Bill Chase (08-10-2022)
Car: Camaro
Engine: 6.2L
The 4+3 was made by Doug Nash who has a wicked rep for building tough racing trannies but the 4+3 was not one of his career highlights to say the least. I don't know how strong they were but it had an electric actuated overdrive that you could use from second on up hence the 4+3 name. I wouldn't waste my time ever trying to swap one thats for sure. Anyone know the actual torque rating these things had?
it was a super t-10 with an overdrive. So a decent tranny, just a touchy over drive unit, usual problems were related to switches after 15+ years, and lack of care.
A good idea in theory, there were revisions to rebuild kits to fix common problems.
88SS6SPEED
11-11-2015 07:05 AM
1bad91Z
07-23-2002 09:50 PM
CamaroX84
06-25-2001 01:26 AM
