700R4 banging into drive
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
my tranny shifts fine in my 89 formula firebird, but if i'm in park, then i go in reverse, then hit the break, and put the tranny from reverse into drive, it makes a BIG CLANG sound... it does this sometimes from neutral to drive too, but not as loud.... does anyone know waht could cause this??? let me know thanks
alright, i'll check that stuff this weekend.. thanks guys
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
mine does the same exact thing... lol what exactly are the u joints? and also ware is the torque arm?
1 Post
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Supposed to help maintain something or other under high torque conditions. I think.
But I would have to say it sounds like your tranny mount is broke.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
1 Post
Car: '72 Chevy Nova
Transmission: TH350
Originally posted by Apeiron
It's the only thing keeping the differential from turning instead of the wheels.
i'll check the tranny mounts as soon as i can...... i might bring my car into my dads friends shop tomorrow, or this weekend at the latest to get my GTA rims mounted... good news THEY ARE STRAIGHT hehe... well i was excited... anyway, i'll let you guys know if it was indeed the mounts... thanks!
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
damn thats not good cause that'd mean my tranny mount is broken. It does it inot ever drive gear, 1st 2nd, Driver, Overdrive, and Reverse.
What will happen if i dont get it fixed right away? Will the tranny fall off or something?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
No, the trans will hit the floor pan or smack the crossmember if the trans mount is completly busted. The transmission and engine are bolted together and supported at three points: both motor mounts and the trans. mount
