700R4 to a TH350...?
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
im buying a TH350 from a friend thats been totally overhauled, and shift kit installed, with a small stall converter, and my question is, how do i reconnnect the torque arm (bar that runs parallel with the drive shaft) to the TH350? is the bracket that it slips into on the tail shaft or the case or the cross member??
anyyyyy help will be greatly appreciated as im trying to get my car ready to drag next saturday.
thanks
thanks
Car: 86 z28
Transmission: built 700R4
check out spohn's website he has all the stuff needed to swap to the turbo 350 or 400. you should need a new trans crossmember to relocate the trans mount and mount the torque arm to.
spohn sells a complete set up for the 700r4 to turbo 350 swap. im not sure of the part number but it comes with trany crossmember and torque arm that bolts right to the crossmember. i think u can get a driveshaft loop with the kit too. i was looking at it for my camaro (in sig) too.
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
