TH-350 Heavy Duty Rebuild Kit
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I want to rebuild the th350 tranny in my 82Z and would like to know of a good heavy duty rebuild kit. I would like to try and rebuild it myself. I will be getting the Ron Session's Turbo Hydra-Matic 350 book soon. I am looking for a kit that will last a while behind a solid roller cam 383 in my sig making more then 400hp.
I've found several kits around but am unsure of which kit will work the best and last the longest.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Get one from BTE, all our race trannies are built with these internals and have been just awesome. Invest in the better drum/sprag as well since this is the TH350's weak point. Oh, the book your getting is the same one I got under a pile of dust an inch thick. After reading through it, finally made more sence to pay my guy $150 since he knows trannies inside and out and knows how to tweak and tune these things...something this book or any book will never be able to do
Car: 82 Z28
Transmission: TH350
Ok thanks, I went to there website and they didn't have any rebuild kit in the online catalog. So i ordered a hard copy.
Finally went into the throne and got my catalog for a TH350 that's non-lock-up part number is 359000 $109.95. Conatins everything needed to rebuild and freshen up your tranny.
high performance clutches, seasls, new bushings, paper/rubber kits, rings, filter and reusable pan gasket.
You can get the racing kit and that includes everything for a light freshen upaper/rubber kit seals and sealing rings. p/n 358600
TH 400 $104.95 master overhaul kit 449000 race kit $34.95 p/n 448900
350 drum w/ 36 element sprag p/n 343900 $264.95
400 drum w/ 34 element sprag p/n 443900 $195.00
tonys91rs
10-10-2015 03:31 PM
83 Crossfire TA
09-08-2015 12:06 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
