9-bolt pinion depth
Old 05-17-2004 | 08:56 PM
cwalsh's Avatar
Car: 2004 Corvette
9-bolt pinion depth
I know this subject has been beaten like a dead horse on this board, but has anyone actually measured the pinion depth on their 9-bolt before swapping gears? I know I did not and I have since then changed pinion bearings and still have a whine that I know is from improper pinion depth. Now I know what a good pattern should look like but the reason why I am asking is how can some one tell if they need a .001" or so by a grease or marking compund???
Also I have aftermarket gears that I believe have no ,marks what so ever on them. They cam from Miles.
So if you took the time to read this whole post, thanks! All I really want is one little number.
Chris
Old 05-18-2004 | 04:51 AM
ede's Avatar
ede
pinion depth is differant for each gear set, even if a lot of them have the same pinion depth. so checking an existing set up may or may not help you. sorry i don't know the number, or even a number close to the number.
Old 05-18-2004 | 07:23 AM
cwalsh's Avatar
Car: 2004 Corvette
thanks
InfernalVortex
04-20-2021 11:31 AM
BrianChevy
Wheels and Tires
08-08-2019 02:16 PM
gord327
10-03-2015 01:25 PM
gord327
09-29-2015 10:18 PM
UltRoadWarrior9
09-02-2015 08:24 PM
Quick Reply: 9-bolt pinion depth
