How do you install a spool in a car that has a posi?
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
My posi is CRAP. I don't drive this car on the street a whole lot, so a spool would be a nice cheap solution. Since the posi is also the carrier, how would you install a mini-spool on a car with a stock posi such as my 88 bird??
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Originally posted by ede
mini spool replaces the spider gears
Originally posted by Ricktpi
on an open carrier.
on an open carrier.
i even have a new unused mini spool sitting around somewhere i'd sell for less than a new one from the store.
Car: 84 Camaro Z28
Engine: 305 L69
Originally posted by five7kid
Forget the spool. Weld the spiders, be done with it.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Well, I'll admit I haven't seen anybody do it for a little over 30 years. In that case, it wasn't the welds that had a problem but the driveshaft that suddenly couldn't handle the new-found traction (5000 RPM launches probably didn't help, either).
But, if he has to buy a different carrier to install the mini-spool, it'll be a lot more than $50. And, the only ones I see are Richmond & Summit for 26-spline axles only, and cost closer to $100. And, they are for dirt track use only, not drag racing.
Full spool is a different matter. But, don't see anybody that offers them for 7.5/7.625".
Ever tell you about the guy that made his open carrier into a "posi" by stuffing in extra spider shims?
Never mind. If you're changing carriers, either get a posi, or an open into which you put a PowerTrax.
hectre13
12-11-2023 08:14 AM
1992 Trans Am
05-10-2023 07:19 PM
AkDrifted
08-17-2015 07:45 PM
1992 Trans Am
08-08-2015 08:16 PM
