Anyone broken a 10 bolt on drag radials?
Just wondering if anyone has broken a 10 bolt on drag radials? I have motive 3.42's with a solid pinion spacer and bfg drag radials? Think with those tires I could actually hook hard enough to break the rear?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i've broken ten bolts without drag radials, so i'd say anything is possible. just pray to the car gods and use the washroom before you go and hope that those few precious ounces you have taken off your race weight is enough to keep the rear end together for a pass.
Hotrodboba400
12-10-2019 07:07 PM
UltRoadWarrior9
09-02-2015 08:24 PM
