TC interchangability 4L60E to 700R4
I have a possible good deal lined up for a torque convertor, but it's intended purpose is for the 4L60E out of a 99 TA. I have a 700R4 in my car currently.
First question- Is the input shaft spline count the same between the 2 transmissions?
second question- Will the convertor clutch operate properly? I know that the 4L60E is completely computer controlled, but the TCC on my trans is also computer controlled.
IIRC, the 4L60E and 700R4 use the same case and bellhousing, so I shouldn't run in to any physical constraints, right?
Anyone have first hand experience here?
The spline count is the same, but the input shaft itself is different, therefore it will not interchange. I could be wrong here, but I have never seen a late model with the early (pre-1998) type input shaft, if it is, I stand corrected, & the TC would be interchangable, as it has a "better" design lockup clutch.
Car: 92 Trans Am gta
Engine: 305 EFI
i just finish puting my tranny that i rebuild an i tougth of the same, an i did, i put my 96 torque converte from my 9c1, on my 92 700r4 from my ta, an it works fine i haven't taken it on the highway jet, it went right in. i just need to know what the stall speed of the stock torque of my t/a.
Whats a 9c1? The new converter went right on, and there's no play between the converter and the input shaft?
My stock converter in my 87 IROC seems to stall at about 1500 rpm, but it may be even lower than that.
Engine: 305 EFI
a 9c1 is a police packege caprice, it's has a lt1 with 4l60E, yes it went rigth in, no there is no play on the shaft, it runs fine an it shift smoothly, the only thing is that the stall on the 9c1 is higher that the stock on the t/a. haven't hit the gears hard jet,
Car: 1989 Trans Am GTA
Engine: 350 5.7 L98
modular tranny controller
I guess that either way that elimates the LS1 convertor then
Back to Ebay!!!
EDIT-- Do the earlier 4l60e's have the better designed TCC that probuilt was referring to?
Back to Ebay!!!
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
