Please help with 700r4 build up!
Old 03-31-2004 | 11:13 AM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
I am going to get a 700r4 to replace my turbo 350 and I have a few questions.. I want a stall of around 2600-2700 who makes good torque convertors for that area and where can I find one...I also have heard about people using vette servos as well...how does that work and where can I find one...Last question with regards to shift kits what are your opinions about it and which one should I use and where to find it..Thanks for your help..
Old 03-31-2004 | 11:34 AM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
well let me start off by suggesting Raptor. they specialize in the 700Rs and make a good product from what Ive seen. they also have a servo available that has even more holding power than the corvette one. I say check their site out and see what you can find out there.
Old 03-31-2004 | 11:48 AM
Car: 89 camaro RS
I have no clue what site that is>
Old 03-31-2004 | 01:00 PM
Killer_Firebird's Avatar
Car: 88 Firebird
Engine: 305ci, 5.0L
Here's a few locations to get one.
Hope this helps you out.
http://www.700raptor.com/
http://www.transmissionhead.com/
http://shop.store.yahoo.com/performa...700raptor.html
While this is just a few places to get the Raptor transmissions, there are no doubt more out there. Some of the other members might know where to get one for a little better price. The only downside's to the 700R4 that I know of would be the fact that if you we're to drag with someone who has the 350TH or the 400TH, second gear in the 700R4 will allow you to lose a little ground during take off, however not enough to really worry about. The other problem would be the reverse planetary cracking appart sending debris through out the transmission. If a planetary goes, you'll know it. Sounds like a tire blowing out. Good thing is, the inside of the transmission is so confined, only small parts of the planetary gets into the fluid system and the car is still drivable for a short time. When mine went, I was able to drive for about another 80 miles before it finally quit. At least it got me home. Best thing about the 700R4, gas milage. With 210,000 miles on my Firebird, I still get approx. 20/27 MPG.
Old 03-31-2004 | 02:22 PM
Car: 89 camaro RS
thanks guys
Old 03-31-2004 | 07:58 PM
Pro Built Automatics's Avatar
Go to http://www.pro-built.net/index.cfm?f...t&productid=35 and see if this what you want? Let me know if I can be of help?
Old 04-01-2004 | 11:22 PM
Car: 89 camaro RS
THanks but I cant afford a pro built tranny...I just bought a regular 700r4 today for a steal and it works great but it just shifts to normally for me...lol...Here are the parts I am thinking of using a Raptor billet servo, Raptor billet overdrive servo, raptor mega valve, Hayden tranny cooler,Raptor street raptor torque convertor, Raptor low/reverse boost valve....THis is going on a fairly mild 350 it will have around 325-350hp when I am done with it... Does this sound good or should I throw in some other things...
Old 04-03-2004 | 09:04 PM
Thirdgeniroc's Avatar
Car: 86 iroc
Engine: 355 TPI
Go to www.bulkparts.com you can get the SAME parts for half the price. Save yourself some money if you can put the parts in yourself it's worth taking a look.
Old 04-03-2004 | 09:47 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
www.700r4.com
great trannys, had one in my friends formy... shifts sweet - he has the stage 3
Old 04-04-2004 | 01:48 AM
First, the Corvette servo will work fine, and the same for the OD servo. Thes others are "overkill". Install the Trans-Go Performance Shift kit (modified) and you will get everything necessary to do this right the first time and you will keep the smooth part throttle shifts, along with firm WOT shifts.
Old 04-04-2004 | 03:38 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Listen to Dana, he know's what he's talking about.
Old 04-04-2004 | 09:29 AM
Car: 89 camaro RS
So your saying all i need is the corvette servo and the transgo stage 2 shift kit....if so thats awesome....
Old 04-04-2004 | 01:46 PM
fb305svs's Avatar
definately don't go with anything more than a vette servo...
Old 04-07-2004 | 08:12 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
What do you modify in the Trans-Go kit?
Old 04-10-2004 | 09:51 PM
Car: 89 camaro RS
yes I would like to know too on the shift kit.....I cant decide which one would be better the heavy duty $75 one or the street/strip $148 one....really what is the biggest differences.
RyanJB
Members Firebirds
39
11-20-2018 03:30 PM
plm99
Southern California Area
11-16-2015 05:21 PM
Jorlain
10-08-2015 01:57 AM
junior419
09-22-2015 03:19 PM
89newfun
09-16-2015 09:28 AM
Quick Reply: Please help with 700r4 build up!
