Axleshaft endfloat?
Car: '85 Z28
Engine: 305 (H code)
Axleshaft endfloat?
Hi
I just put my '85 Z28 in for its annual roadworthiness test (what we in the UK here call the 'MOT' or Ministry of Transport test) and the mechanic failed it on rear-axle bearing rock, but to me it looks like endfloat at the wheels - I can't get the wheels to rock at all but they move in & out about a sixteenth of an inch or a little less.
The mechanic is adamant it's unacceptable.....
The question is, should I expect to see endfloat, and if so, what is an acceptable amount?
Thanx
Malc
Thanx
Malc
Car: 4
Engine: 6
Transmission: 5
1/16" (2mm) is about right. They all have about that much, sometimes more.
Sounds like your "roadworthiness inspector" needs to get checked out by the "car knowledge inspector".
Car: '85 Z28
Thanx RB83L69 - my last post went before I saw yours.
I'll pass this back. Can't see any mention in the Chilton or Haynes books so is there anywhere I can get this a bit more official if he screams and hollers? ;-)
Malc
Malc
1 Post
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
1\16th of an inch endplay is perfectly acceptable on C\clip cars. Being in the UK, the inspector is probably not familiar to GM cars using C\clips. Most European cars do not use this method.
Hard to find specs on endplay...but take it to another inspection station with an inspector who is knowledgeable about GM c\clip rear ends.
C\clip replacement will may not help, although it;s certainly worth a try. On my car ( 10 bolt and Eaton Posi ), with new C\clips, the endplay was .050". Not a problem with PBR rear brakes ( sliding calipers ), but when I switched to 4-Piston WilWoods this caused pad knock back and an inconsistant low pedal.
Solution was to machine some " Lash Caps " that fit over the end of the axles ( between the axle end and the pinion cross shaft ).
Again...not necessary with stock rear brakes.
1 Post
Car: 86\92 Mutant
Engine: 355CI 430HP
You might find this link interesting. Dirt cheap way to eliminate virtually ALL axle end-play....
Thicker C-Clips
Thicker C-Clips
TomP
03-19-2002 03:39 PM
TomP
03-19-2002 03:15 PM
TomP
03-11-2002 03:08 PM
TomP
03-11-2002 01:38 PM
