Speedo cable lube
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Speedo cable lube
Have had to lube a couple cables in my lifetime, speed cable lube is getting hard to find. Will LUBRIPLATE WORK FOR THIS ?
Have been using regular speedo lube with graphite and have had to lube the cable in my '86 Caprice three times in about 18 months, that's bull, once should have been a done deal for years.....however the stuff looks pretty runny.
Anyone know of a good substitute that will last ? Lubriplate ?
P.S. Does my '87 and '89 TA both have a speedo cable ?
Thx
Bill
Thx
Bill
Car: 4
Engine: 6
Transmission: 5
Spray can engine degreaser; let it sit a while; follow with spray can carb cleaner; blow out with compressed air. Make sure the carb cleaner doesn't get on your paint.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Re: Speedo cable lube
Originally posted by jmd
Heh. Graphite is an abrasive.
Using Graphite in a speedo cable is like jerking off with sandpaper. (not said from personal experience.) It only works momentarily, and just ends up hurting things.
Almost every speedo cable cable lube you pick up will say liquid graphite or with graphite or something to that effect........:werd:
Bill E.
1 Post
Car: 1990 Formula
Transmission: WC T5
not that I am aware of.... Yes it may be abrasive to some soft plastics, but not for a metal or hard plastic surface.
Z28/ZR1
10-23-2015 01:04 PM
TMZIrocZ350
10-07-2015 12:09 PM
