i need a speedo gear. please help me lol.
Car: 1987 IROC-Z
i need a to replace the speedo gear in my T5, went to the dealership and they have no idea wich one I need, i need ot tell them how many teeth it has etc. etc.
So i ask all of you, how many teeth would a speedo gear have for a 3.23 rear end & 255/50/16 size tires, I honestly dont even care if it's a bit off, I'm just sick of this thing throwing a vss code and running in home limp mode.
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
i have your problem. my cars a 91 z w/ elctric speedo, and it has 273's. it has a 5 spd from a 86 firebird. and i cant find the gears i need eitehr. i ahve to go to a speedo shop near my work and ask em about it and tehy will make gears. one for the trans. output shaft and one for the speed sensor or cable. i think its called dicks speedo and tach.
2.73's had 17/37, as for 3.23's just call different dealers and eventually you will find one that knows what they are talking about. I had to call 4 different ones before I finally got a competant parts guy.
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I appologize if I'm a bi tharsh here, but why don't you just pull the gears out and conut them? If you just need a replacement, it's just that simple! Even if you have a wear issue (sounds like you do), there should be enough left to be able to count. If you want to get pretty darn close, I have the info you need, let me know!
Car: 1987 IROC-Z
i'd rather have it on hand seing as how once my trann is taken apart i wont be abl to driv to the dealership lol.
I can do speedometer gear calculations and find you the best gears possible. The only problem is, I don't know what gears are availalbe for the T-5. All my research gives me gears for the Ford T5, but I can't find anything for the GM T5. If someone can tell me the gears available (number of teeth is all that is needed) I can calculate anything you need.
Car: 84 Z28
I'm looking for my info I had somewhere around here! I got it from someone on this board, but don't remember that either!
23/9 would be a pretty darn close combo of gears for him IMO.
Car: 1987 IROC-Z
Today is a perfect day toinstall it so if someone gets me a speedo gear no. I woill be ever so greatful
Car: 4
Engine: 6
Transmission: 5
If it's a T-5 car, you need a 7-tooth drive gear and a 19-tooth driven. It actually works out to 7 and about 18.55, but you can't exactly buy one like that... 19 will have to do.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by 5SIZ
for me!? if so then thats good nough lol. I honestly don't mind it being a bit off, I was driving my car w/ a speedo gear for a 3.08 rear end and I was only 3 mph off. Besides I know my speed w/ the tach.
Well here are the speedo geards I got for my 3.42 gears. This is not quit 3.23 but you said it could be close.
GM and Ac delco part numbers are the same.
Ok here are the numbers.
For the round purple one
ACD# 14071731
GM# 14071731
and for the shaft mounted one
ACD# 14090592
GM# 14090592
Transmission: t-5
shifty,whered u get the speedo gear w/ the teeth on the inside. all the idiots at the gm dealership kept giving me gears w/out teeth on the inside which were all to big. what kinda tranny are they for? what year make n model would be nice,thanx
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
14090592, 273, 308, 88, chevy, dicks, differemtial, gear, gears, gm, replacement, speedo, speedogear, speedometer, t5
