how to change peg leg to posi?
Car: 85 trans am
Engine: 79 4 bolt 350
i dont know a whole lot about rear ends but i would like to change my peg leg to a posi rear. now can i just change the internals or do i need to change it all out for an entire posi rear end? might be a dumb question but im not sure about it. thansk alot
1 Post
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Well, your best going off and just buying a 90+ rear end with posi. You have an 85 which had the 26 spline axels. You can find rear ends pretty cheap and will save you money rather than buying a posi unit + pinion and ring gear.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: how to change peg leg to posi?
Car: 92 Cherry Camaro RS
Here's a direct Bolt in Posi Unit.
This is what i am considering since i am not ready to change out my gears. This is supposed to be an easy install.
Powertrax
Powertrax
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
i wouldn't go that way....cheap is cheap... lockers can be tough for daily driving, and a good way to snap an axel... especially them 26 spline ones... seen it happen already! driving the car can be difficult at times too, since a change in speed is what disconnectes the locker- makes plenty of noise and *** help ya if it starts actin up on ya in a corner in the rain....
not to try sellin parts outside the classified, but my best bud is sellin his auburn posi and 373 gears for around 250 bucks... its for a 26 spline rear- he bought a new chassis to put his motor and trans in, and it happened to have a 3.45 9 bolt which should hold up fine for his combo... shoot me a pm and i can get ya details on it if ur intrested- no more than 500 miles on the stuff, trans broke and the car has sat since waiting for warmer weather for the transplant.
anyways, side note - not very many 90's had 28 spline axels. this was the chnage over year and gm cleaned out there 26 spline parts bin before they switched over completely... i pulled several 90 rear eneds apart looking for 28 spline axels and found NONE... however, 91-92 are sure bets for 28 splines
Steve
Steve
89 might have been the change over year, but from personal experiance, its like finding hens teeth to find an 89 with 28 spline axels, and a lot of 90's also didnt have the 28's either...
i did find that the higher end models, like the z28 and the formy with the posi option, and the gta's had the 28 spliners...
hectre13
08-26-2015 08:17 AM
