Difference between disk and drum brake axles?
Car: '87 IROC
Transmission: 700-R4
im looking for a set of axles for my 87 IROC w/ a 10 bolt and my dad said he found out that the disk brake and drum brake axles have different part #'s. does any1 who what the difference is? my car has drums on it now,but i have a disk brake rear (a complete 1 from an 86 IROC) that i was wanting to put in it.
thanks for any feedback
Car: 1986 Z28
Engine: 1997 LT1
Dude, dont wait, put that bad boy in it will bolt right up, probably the difference in #s is the rotor/drum differences. good luck. By the way, a rear end from 82 to 02 camaro/ ta will interchange, just minor parking brake cable work is involved.:rockon:
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
you're telling me that all 3rd and 4th gen rear ends are completely interchangable? If thats true...do the 4th gens use a 10bolt or 12?
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
4th gen rears are same as yours 7 1/2 in. 10 bolt, only diff is the 4th gen is about 2 inches wider.
Kevin
Kevin
AkDrifted
08-17-2015 07:45 PM
