What VSS sensor connects to this tailshaft?
1 Post
Car: 1986 IROC-Z
Below is a picture of the output shaft of an NP205 transfer case, which I'm swapping into my Jeep Wrangler. I'm doing a full Chevy driveline, with a 350 TBI motor.
Obviously, the t-case is set up for a mechanical speedometer. I have both an electric and cable-driven speedometer available, but I'd much rather use the electric gauge.
If I went electric, I'd ideally need to find a sensor that would bolt right up to the threaded mount. I could then run a VSS buffer into the ECM, and the rest of the signal into the speedometer. Everybody would be happy.
I saw this post, in which a Grand Wagoneer's VSS sensor is discussed -- but I don't know if it'd bolt up to my GM transfer case. The VSS sensor in my Wrangler is removable, but it's not threaded onto the gear (it's bolted in place like a distributor).
Any thoughts on how I can do this electrically, without using one of those expensive intermediary boxes?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Magnetic speed generator
Painless sells a unit. It goes in between the cable and the trans and has two wires that go to the buffer.
[Sold] T5 electric speed sensor
Eric-86sc
09-07-2015 02:10 PM
