ford 9-inch or ford 8.8-inch rear end...??
ok so Eaton Posi has an electronic differential that with the push of a button can go from locked or limited slip but for a ford 8.8" rear end. is this the same as a 9 inch?
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
No. They are totally different. No parts interchange.
ARB definately makes an air locker for the 9", but be prepared to pay. The locker is like $500+, and then you need the compressor for another $250. Don't get me wrong they are great, and very tough, but they aren't cheap.
A lot of 4X4 guys run them in the front axel, because it allows them to unlock the front end to regain a tighter turning circle whent hey get into a tight spot on the trail.
