all 3.73s are 3 series??
i ask this because when i layed my 3.73s --oem gm gears-- on my posi i got from slp....the ring doesnt uh...go on the bottom base of the posi unit....is this normal?? do i have to press the ring on?? or is it possible i have 2 series 3.73s.....all the bolt holes line up...the ring just sits too high by anbout an 1/8 of an inch...heres a pic....
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Just from looking at the thickness of the ring gear it appears you have a 3 series gear to install in a 2 series application. The ring gear can be a snug fit. 2 of my ring gears had to be tapped into place on the posi while the very first one slid right on. When I had my 3.42's installed onto my 2 series posi I had to use a spacer that was apporx. 1/4" thick-but dont quote me since I never actuallt measured it and that's another reason I believe your gear is for a 2 series carrier, both of my recent victims were 3.73's and the ring was'nt that thick. But without having it on front of me it's hard to say since I have'nt measured ring gear thickness. As many as I've gone through this year I should know all there is to know by now, junk azz rears anyways
nah i finally got it to snug down to the base of the carrier, these were oem gm gears by the way.....i just snugged the bolts down with about 1 lb of pressure doing 1/4 a turn on opposing sides and it finally drew down.....now if the ring ever has to come OFF the carrier, thatll prove to be interesting lol
nah, im staying away from big *** hammers...i cracked a 4 bolt 350 on the lip of the oil filter housing with a BFH lol....the crack is OK, no crucial damage, other than costing me a pair of new undies
but yeah, NO MORE HAMMERS! lol
UltRoadWarrior9
04-28-2020 10:39 PM
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
