Fluid capacity of 91 7.5" diff
Car: 1998 Z28 convertible
Transmission: 700-R4
Either my shop manual is missing the page, or simply does not have it- but what is the fluid capacity of this diff? I have installed the SLP Torsen takeoff with some 3.42 gears out of an S-10, and want to add the gear oil while the cover is off and diff is sitting on sawhorses...
ede, thanks for the help, but I already knew that (even have a pump for it...). It is much easier to fill a diff on the bench with the cover off.
You need to get a numerically larger carrier to run 3.42 and up gears; you're 3.08 won't do it. Also, check on the splinecount, either 26 (1982-89)or 28 (1990-2003) S-10's, especially manual 4 cylinders are excellent sources of 3.73 and 4.11's.
