tremec 3550
Old 12-17-2003 | 06:30 PM
JOHN MERCER's Avatar
tremec 3550
i'am thinking of buying a 3550 for my car but i have read some posts and it's about 50/50 that the 3550 makes a lot of noise in the gears is this true or just rumors any feed back would be nice by people who have one i hate to buy one and find out it's makes a lot of noise or i'll just stay with my t-5.
Old 12-17-2003 | 09:25 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Well the 3550/TKO will make more noise due to the cut of the gears. Most people turn to this trans due to strength. Why are you considering it?
You may want to find someone local that has one to decide. Noise is very much a personal preference. I don't think that it is all that bad. Fifth gear is the only one that is a bit annoying to me but it is still tolerable. What I think is ok may not be ok with you.
-Schultzy
Old 12-17-2003 | 10:07 PM
tremec 3550
gta89 thanks for your reply all i'am looking for is a quiet transmission i don't care about strength of the tranny.
Old 12-17-2003 | 10:23 PM
tremec 3550
also i'am looking for a new tranny because my world class t-5 is worn out it needs new gears so i thought it would be a good time to update to a new 5 speed.
Old 12-17-2003 | 10:46 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 10 Bolt 3.73
I have the TKO and it's pretty noisy in 5th. Not much more noise in the other gears, but I bought it for the strength.
If you want quiet and don't need the strength, save your money.
My 2 cents.
-Rich-
Old 12-18-2003 | 02:08 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The Tremec 3550 is noisy all the time. A friend of mine runs one in his '95 Cobra. My T56 makes about the same amount of noise though. I also run a Pro 5.0 shifter with no rubber whatsoever, and only have one boot over the shifter, as opposed to the two that factory 4th gen cars have.
Seriously, I would just rebuild your T5. Parts for it are really cheap, and it is a quiet, reasonably strong unit. The gears can be upgraded to better material too, and even if you did this it would still be cheaper than a new Tremec. Call Bob Hanlon at Hanlon Motorsports 1-(610)-469-2695. The super alloy gear sets are about $450 and the rebuild kit will run about $185, and it has every bearing, clip, and seal you will need. He also offers a factory service manual that covers the rebuild, or he will rebuild them on an exchange basis. I've already done three for Mustangs, and they are very easy to work on.
Old 12-18-2003 | 04:03 PM
tremec 3550
thanks for the info tko.
Old 12-19-2003 | 09:28 PM
Yeah man, no problem.
Old 12-20-2003 | 10:33 AM
AllGoNoShow's Avatar
I got an 81Z with a TKO and maybe its the straight through mufflers dumped at the rearend but I don't notice any noise coming from the tranny! I also put a good amount of insulation over the shifter hump and just cut a small 1 inch hole to get the shifter handle through. Definetly a great investment in my book...its nice to not have to worry about breaking a tranny until I'm up in the 600+Hp range...theres a lot of mustang guys running these trannys in the 10s stock and also some in the 8s with the rebuild kit/modifications TKOPerformance is talking about.
Old 12-20-2003 | 03:17 PM
thanks NOGO for your input.
topteam54
10-06-2015 01:21 AM
3RDGENFRANK
12-24-2001 06:01 PM
JoeCool
09-27-2001 09:13 PM
Scottlb9
08-30-2001 01:04 PM
JDMZ28
09-12-2000 03:29 PM
Quick Reply: tremec 3550
