4th gen rear swap??
Car: 91 camaro rs
Engine: 350 sbc
Transmission: b&m 350
Axle/Gears: borg warner 9 bolt
4th gen rear swap??
I have a 91 rs camaro with the limited slip diff. I just installed a 350 with 11:1 comp fulie heads air gap man with a 600 carb. Im afraid that with my new found hp i will blow the rear end right off with a few hard launches. I cant afford a bullet proff rear end right now from moser so i was wondering if i can do a swap with a 4th gen camaro. Im looking for a posi rear with 3.73 gears, im just wondering if its a clean swap or do i have to do some fabrication and if so can i work my way around it by buying and adapters. Im also worried about the brake lines my drum brakes and suspention crossing over to the new rear will there be problems?? any kind of help would be nice thanks alot!!
Car: 91 camaro rs
Engine: 350 sbc
how does it look
You think that will look bad from the back or it should be ok i really dont want the tires sticking out like one of those green 89 toyota corrolas you see running around with 10 in gold wheels.....lol you know what i mean
Car: 91 camaro rs
Engine: 350 sbc
duhhh
yea im a freakin idiot i knew that.... thanks for the help ede your the man .....
You looking at the one on ebay? I am looking at this one http://cgi.ebay.com/ebaymotors/ws/eB...tem=2441450767 he is also selling one with 3.73 posi.
Later
Barrett
Later
Barrett
Car: 91 camaro rs
Engine: 350 sbc
thanks alot
thanks alot for the info guys im a new member here and i learn more about my car in three days than i did in about 2 year. I say screw a haynes manual. To sum it all up i have one more question if i where to get a whole rear with the brakes already on it will the fourh gen rear come with drum or rotor brakes and will it really matter?
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
AkDrifted
08-17-2015 07:45 PM
