t5 and a bb
Car: 1987 iroc
Engine: 434 bbc
Transmission: 350 turbo
t5 and a bb
will the t5 bolt up to a bb?what about the flywheel?switching from a 350 turbo,will there be problems with the cross member?this will mostly be for cruising,and a li'l flogging with no slicks or et streets.thanx
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
long as you have chevy bolt pattern on the trans/bell houseing and a sbc it'll work. i belive the crossmember will also work, but you need to double check me on this
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
