Aliminum Driveshaft
Car: 91 Z28
Transmission: built 700R4
Aliminum Driveshaft
I was wondering if I can fit an aluminum dirveshaft from a an 80s corvette in my 92 RS with an auto 700R4 trany. thanks
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
i dont think u can, they are smaller i thought.
you can use 3rd gen and 4th gen f-body ones though.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2437056019
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2437222560
Car: 91 Z28
thanks, I had the first one saved in my ebay already. Just thought a Vette one might be a little better. not sure what lenght mine is but the vette one is 33"
welcome to the boards and since ur from MD check out the mid-atlantic board.
https://www.thirdgen.org/techbb2/for...?s=&forumid=42
Car: 91 Z28
and more expencive. at least that is what I have found so far, let me know if you find a 4th gen for around 50 bucks:hail:
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
go to the local pick and pull, i have seen them there, and there about 25 clams, i have one for mine!!!! :rockon:
Originally posted by bes217
Why not a fourth gen one. They are the same as the 1LE and easier to find!!!
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
the 4th gen stock aluminum units are a lot nicer then any other OE shaft GM used. the aluminum stock shafts in the 4th gens are made by three rivers american axle and manufacturing. their nice, 3" tubing vs 2.5 of the 3rd gen alum shaft. forged yokes, and a harmonic balancer. i just got one for 125 dollars, 146 shipped:
Car: '88 Firebird Formula
Engine: 360hp/417ft. lb. 350
Transmission: Pro-Built Street/Strip 700R4
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
Car: 4
Engine: 6
Transmission: 5
Hardly even a bolt-in.... more of a slap-in.
With air and a lift, it's about a 2-minute job. It takes me about 3 times as long to put my car's rear on jack stands (floor jack under the center section, 2 stands under the axle tubes) as it does to change the drive shaft.
Car: 4
Engine: 6
Transmission: 5
Yes, it seems to.... think about it..... 10% balance error in that light shaft causes about as much vibes as 3% balance error in a heavier steel shaft....
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i got a bad vibration at 80-88 mph (the fastest ive gone in the 1/4) and ive been thinkin of gettin a alumin drive shaft, i just gotta mesure mine to see if its the same lenght as the 4th gen since i got a th350 tranny.
also do all 4th gens with v8's have the alumin driveshaft or is it just the 4th gen LS1's?
The LS1 shaft is by far the slickest option. Great reputation for ride comfort as they come balanced real well and also employ a harmonic dampner, great for fast reving rpm motors. Considering that the LS1 F-Bodys ran the most advanced small block to date one could assume that GM had a design team put alot of thought into choosing a driveshaft as well. Not to mention there are a ton of LS1 cars running 11s on that shaft.
I run one.
150$, bought local. There is a 4th gen wrecker that slings em here in Phoenix, they are for sale all over the net as well.
I run one.
![good job!](https://www.thirdgen.org/forums/images/smilies/goodjob.gif)
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i just put in a ls1 driveshaft in.. picked it up around 150 ro so shipped. the only thing i will say is that its a bit hard to put in with a 3inch exhaust without taking anything off. however that said i did it and im very happy with it. i agree its the best option by far over the 2.5 aluminum one.
Car: 91 RS
its alot more stable at higher speeds then before and better accerlation all across the RPM's... its a nice very stable drivshaft .
Car: 91 RS
one more thing to note, i think its a biot strong then the stock 2.5 inch aluminum drivesafts . also if it can hadle an ls1 motor, it can hadle alot of of mods with a 3rd gen.. heck you could even swap to a bigger motor and be fine.....
Car: 91 RS
i do beielve so see as its made form a 4th gen and the t-5 and 7004r use the same outputs and lenghts of driveshaft
Car: Black 1984 Chevrolet Camaro Z28
Engine: LG4 305
Do any of the v6 fourth gens have aluminum shafts? That is all the 4 gens my wrecking yards have.
Car: 1986 Trans Am
It is my understanding that the V6 cars employ 2 pc. driveshafts. I'm not sure that would work well with out alot of effort, provided it was the same length.
Think one would fit in mine? Th 350, still using the same dive shaft from the original motor ( th 200 ) and it fits fine in the th 350, but i think the th 700r4 have a shorter shaft??? not sure, but think i read that in a manual somewhere.
Car: 4
Engine: 6
Transmission: 5
No, the aluminum shafts are a different length than the 200 shaft; so if your 350 uses that shaft, it won't fit the Al one.
One of the 350 lengths does fit it, I believe it's the one with the 9" tail, but I'm not positive of that. It is not however the one that's the same length as the 200.
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
topteam54
10-06-2015 12:21 AM
