Who builds the best 700-R4?
Old 10-07-2003 | 01:21 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I'm going to need a transmission soon and I want to know who builds the best 700-R4. I want the shifts to be super hard and I still want it to shift on it's own in OD.
Old 10-07-2003 | 10:26 AM
MdFormula350's Avatar
www.pro-built.net
as far as i can tell from my research.
Old 10-07-2003 | 11:01 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I love my pro built Street Strip 700-r4. Dana builds some mean transmission and he's recently upgraded his designs now they hold 625 hp they use to only hold 550 hp. My 550 hp version is suppose to shift fine down to 10 second 1/4 mile after that there are a few things that can be done for quicker shifts, but how many of use run faster than a 10.0 1/4? You might think about trying out the 9.5" ACT convertor also. They're pretty decent, I have a 2400 rpm lockup on my stock motor and I like it.
He using all new parts with racing clutches, trans go shift kit, and about everything else you can think of. You can even request some certain upgrades. I had my OD downshift blocked so I can go 100% throttle in OD without it downshifting out. Makes it awesome for passing on the interstate. Otherwize it still performs like an automatic upshifts fine on it's own and will downshift at the right speeds. My block only effects the downshift that is done at more than 70% or so throttle.
He also sets it up so it stays stock type feel at light throttle and increasing hardness as you give it more throttle on the shift points. I had a B&M shift kit in my OEM transmission it was ok but I got tired of it chirping the tires every single 1/2 shift and the whiplash effect even when cruisin slow. Not to mention it was a pain to drive in the rain since every 1 to 2nd shift would kick me sideways.
Old 10-07-2003 | 11:40 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Probuilt is the best in my opion. I smoked a TCI and a B&M 700R4 before I found out about Pro Built. Bought the Pro Built tranny with the ACT converter and have not had another problem. Not only is his trannys hell for strong, but you will not find anyone that will give you the kind of customer service that Dana will. He spent alot of time on the phone with me making sure I was getting what I wanted. As long as Pro Built is in buisness I will never buy another automatic from anyone else.
Pro-Built :hail: :hail: :hail:
Old 10-07-2003 | 12:26 PM
Engine: 383 SBC
Yep, exactly I called several times and his phone was busy so he told me to give my name and phone number and he called me back!! Other companies I've dealt with made me wait on the phone for 30 minutes and when I finally get a person it takes a whole minute to answer my question.
I have nothing but nice things to say about probuilt.
Old 10-07-2003 | 08:01 PM
GASGZLR's Avatar
Thanks everyone. I will definately have to check out Pro-Built.
Old 10-08-2003 | 11:42 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
my choice would be rossler.
Old 10-08-2003 | 11:53 PM
camaro_60181's Avatar
Car: 1986 Iroc z28
http://www.pro-built.net/ I personally never had a Probilt but from what I here they are The sh$t when it coms to 700r4s!
Old 10-09-2003 | 10:20 PM
stone89ROC's Avatar
Car: for now my Jeep while im building my Camaro
Engine: building a 350 with about 440HP and 450lb
Transmission: W.C. T-5 dont know how it will hold up..
http://www.fearthemonster.com
try em out. I have only heard good things about em. They are really reasonable too
Old 10-09-2003 | 10:30 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Stay away from bowtie overdrives, I know 2 people who have had problems with them.
One local dude has one from monster, and it runs good, but it's too late to tell yet, the blue bottle and et streets will test it soon.
Old 10-10-2003 | 08:51 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
www.700raptor.com
Old 10-10-2003 | 11:14 PM
jeremy178's Avatar
Car: '89 Camaro RS
I heard a place called level 10 does a good job on the 700R-4
Old 10-14-2003 | 05:36 PM
Kingtal0n's Avatar
Car: 240sx
Engine: whatever works
Transmission: 4l80e this year
Axle/Gears: 3.512
Probuilt. end of story. you get what you pay for...
Old 10-14-2003 | 07:04 PM
zippy's Avatar
Engine: 5.3L
true, but none of them are cheap. rossler is what's used in the lingenfelter rides, and has the numbers to back them. followed them since i found that out some time ago...
ZEEYAA
04-16-2023 09:29 PM
racereese
10-03-2015 04:46 PM
92projectcamaro
09-29-2015 08:07 PM
Zell1luk
09-29-2015 11:36 AM
Jlanz55
09-29-2015 09:55 AM
