clutch replacement - flywheel
Yeah. You will have high and low spots on the flywheel from the clutch. That needs to be milled flat or you will fry the new clutch pretty quick and have bad problems with slippage. If possible, have it milled, not turned. Milling will give you a flatter surface with less hot spots.
Hope that helps,
Matt
Hope that helps,
Matt
Originally posted by onebinky
If you want it milled stick with the machine shop. All of them around here charge $70-$125.
having your flywheel resurfanced does a few things,
it makes the entire surface flat and uniform, so that the new clutch disc can wear into its own groove.....not interefere with the one created by the old disc.....
also, it removes alot of heat damaged material that is discolored on the surface.
if the flywheel is in really good shape (not all burned up) you shouldnt have to remove much material
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Clutch doctors free when you buy a clutch set. Do it or you'll be sorry.
BlackphantomZ28
04-24-2016 08:14 AM
rsrmoore
08-07-2015 08:44 PM
