Vigilante torque converter
Car: 1986 Trans AM
Engine: 396 LT1 Stroker
Axle/Gears: Ford 9 Inch w/ 3:70 Gears
Hey guys this is my first post to the board. I have a problem with my torque converter. i just installed a vigilante torque converter in my 94 z28 with lt1 and 4l60e trans. I was running 13.4s before the change but after i changed to the vigilante my car is running 13.9's i have no idea what the hell happened. Thats the only thing that i change that would effect the way the car would run. Have any of you ever heard of this or have had it happen to you?
I think the car should have run a high 12 with the converter change?
Tom
Mods:
K&n cold air intake,1Le high flow bellow,flowmaster exhaust,CAt delete Pipe, edelbrock headers and y pipe,electric water pump,accel wires, BBk throttle body, Granatelli MAF, Be cool aluminum radiator,B&M trans cooler,aluminum drive shaft, Miller racing torque arm, LCAs Panhard rod, LCA relocation brackets, sub frame connectors,kyb adjustable shocks, Bigger sway bars front 34 mm 26 mm rear, Ford 9 inch rear with 3:70 gears and locker,shift kit, vigilante converter.
60 foot 1.87
1/4 mile 13.9 @98 mph "Something is wrong with the car big time"
Tom
Mods:
60 foot 1.87
How did your 60 foot and mph change between before and after? I have a vigilante 3200 stall on my LS1 and I will tell you it is probably the best stall money can buy for our cars.
Car: 1986 Trans AM
hello
my 60 foot with slicks and the stock converter was 2.0
mph was 102 and my 1/4 mile time was 13.4.
with the vigilante 2800 stall and slicks it was 1.87 60 foot
mph was 98 and 1/4 mile time was 13.9
thats what i cant figure out maybe i got a bad converter or something?
any ideas, it was installed correctly.
Car: 1986 Trans AM
hi
the weather was pretty much the same
65 the first time when i ran 13.4
95 when i ran 13.9
68 when i ran 13.9
it seems it will only run 13.9 i dont thing 3 degrees will make a 1/2 sec difference ya know.
i agree with you about the top end , is it possible for convertes to slip at high rpm. whne i leave the light it pulls like hell in 1st gear then slowly dies out in 2nd and 3rd.
tom
95 when i ran 13.9
68 when i ran 13.9
tom
Generally with converters it will drastically reduce your 60 ft times while not effecting yout mph very much at all. Something is definitely wrong. It should not be slipping like that. Are you sure you installed it right?
Car: 1986 Trans AM
converter
yeah a pretty sure i pushed it on as far as it will go as i was doing that i rotated it a few time i heard it click in.
This is really driving me nuts.
Tom
Tom
Ragtop Man
09-12-2015 12:23 AM
