Posi carrier swap to non posi rear
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Hi Guys
I have a 3.23 posi and a regular 3.23 in the car. Is it possible to just swap over the posi carrier gear and bearings to the non posi rearend in the car all things being equal?
I am hoping I can aviod a complete rearend swap.
Thanks,
BILL
Thanks,
BILL
as long as you're swapping carriers from same type rears, 10 bolts 7.5/7.62 ring gears and the axle splines match you sure can. just swap the ring gear to the new carrier (making sure you have right series) and check back lash and contact pattern.
Thanks Ede. What is the best way to identify the type of ring gears I have? If possible, I would like to verify the ratio as well.
Regards,
BILL
Regards,
BILL
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
knight72
08-10-2015 09:32 PM
