can i resurface my flywheel again??
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys i put a LUK pepboys clutch in about 5 thousand miles ago and for the first 3000 mile si had bad hydraulics and the clutch is slippin preety good from it being worn and cause it probably cant handle the power i am puttin down. well i had the flywheel resurfaced when i did the clutch and i had it out when i threw the new motor in and it had a few blue spots on it. well i wunt to put a new hayes clutch in it from jegs and i'd like to have the flywheel be right so can i get it resurfaced again or no? Also i work at pepboys and i can special order a flywheel for 130 bucks and i get 20% off of that but do u think they are anygood?? thanks
Car: 89 Formula
Engine: Carbed 5.7
i guess i should ask wut is the minimum thickness for the flywheel so i can mic it and see if it can be cut again? thanks
monte87cortez
09-26-2015 08:10 PM
20, camaro, flywhee, flywheel, heads, luk, minimum, resurface, resurfaced, resurfacing, thickness, thousandths, times, vortec
