will a muncie work?
Old 08-01-2003 | 07:47 PM
will899's Avatar
will a muncie work?
i am putting a zz4 crate motor in my 1983 camaro and i need to replace the time bomb of a 5 speed that is in it now. will an m20 or m21 muncie work? will it just bolt on?
Old 08-02-2003 | 06:50 AM
ede's Avatar
ede
if you have enough time and money you can do anything. couple of things you might want to think about is the torque arm and the manual clutch. if you have a muncie there's a very good chance someone that really needs one for an old car will pay big bucks for it, if you don't have one you could put the money towards a better trans that would be more of a bolt in.
Old 08-03-2003 | 11:15 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
'83s used a mechanical clutch, so that isn't a problem. The torque arm and shift linkage are though.
Old 08-04-2003 | 06:06 AM
ede's Avatar
ede
the location of the fork i nthe bell might be an issue, unless you wouldn't mind it sticking thru thr trans tunnel by your rigth foot.
Old 08-04-2003 | 09:10 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive never seen an early 3rdgen manual 4, but werent they side linkage sanginaws? If so all the parts from one of those should work with an m20+. I know they all have the holes in the tailshafts where a tq arm will mount.
Old 08-04-2003 | 09:58 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
I belive the early f-bodys used BW T-10's, which are side linkage 4 speeds, these transmissions are pretty strong, I had a 70 camaro w/ a 454 that had a T-10 behind it, never had trouble(other than clutches)
Old 08-05-2003 | 03:40 PM
Air_Adam's Avatar
My dad had a '73 Z/28 with a M21 or an M22 trans... i dont remember which, but he said that thing was absolutely bulletproof, and he really beat on it
The T10 is pretty strong too... in a little different form it was used in the later 2nd gens and also in som Hemi and 440-6 pack cars in the late '60s
I've heard that the '82 T10 4 speed are good to about 350hp... thats a healthy number
Terrell351
06-13-2021 02:13 PM
Jake_92RS
01-28-2020 11:37 PM
Vintageracer
01-10-2020 06:33 PM
Jk_Under
08-17-2015 04:08 PM
Fronzizzle
08-17-2015 03:52 PM
