Slip yoke for GM's aluminum driveshaft
Does anyone one how I can replace the slip yoke off my stock aluminum "1LE" driveshaft ? It says "Spicer" on it, so I assume they make them, but does anyone have a part number or a place that sells this kind of stuff ? Thanx
Naah... see it's not that easy. I thought so at first too. Hehehehe...
The way the clips are mounted for the universal joints is different between a steel shaft and the aluminum one. That's why I need that specific type of yoke. :/
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The aluminum shaft has 1310 yokes. You should be able to take it to any driveline shop and they'll know what you need.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
whats diffrent? can you take pics?
im mostly just curious.
