Trans Temp Gauge Install
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I was wondering where I should install a sender for a trans temp gauge. I have the cooler lines where I could put the sender, that is one place. However, I have two places for the in and out of the coolant tank for the trans fluid. There is a third area that has a bolt in it that looks like it plugs the tank up. The bolt is just below the upper cooler line and I thought it would be great if I could just put the sender there. Does anyone have any ideas? I am not really sure how to splice into the cooler lines.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
if its an autometer guage then u have to put it in the trans pan. thats what the instrcutions say to do. so i think when im feelin lucky ill drop my pan drill weld and see if it doesnt leak but i got other things that need to get done.
Engine: 2.8L V6
Yeah I've heard that usually they want you to drill into the pan. This might give you the most accurate reading however you have to put a hole in your pan. I know AutoMeter has an adapter that might fit on the cooler lines. It just would be a whole lot easier to put it there. I thought about a fuel pressure gauge too which would be pretty easy but that thing costs like $150 + so I think I got better things to spend money on.
Engine: 2.8L V6
I've been looking at the 700R4 and I see there are also some plugged areas of the transmission to check oil pressure in the clutches. If I could only find out what size these plugs are I could put the sender there which would probably be best and easiest.
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
A buddy of mine just put one in his car and the fitting that came with the gauge just plugged right into the side of the transmission. There is a plug there that is the same size and the one that comes with the gauge.
