Spedo gear change with electronic VSS
Old 06-25-2003 | 02:06 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Hi everyone,
i am doing a gear swap this weekend, and i have tried searching, tried calling 2 GM dealers, and can't find the answer to my quesiton.
i have a 1990 RS T-5, currently has 3.08's, i am swaping in 3.42's. i need to know what speedo gears to get. the dealer says i have a Red-9tooth drive gear, but he can't tell me what the other gear is, and can't tell me what gears i need for 3.42's i was unable to find a clear answer during my searches, because it seems that there is a large set of gears, and a small set of gears ???
hopefully someone can help me...
thanks
John
Old 06-25-2003 | 02:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You need a blue or purple 7-tooth drive gear and a white 20-tooth driven gear. I don't have part #s.
Large gears = auto trans
Small gears = manual trans
Old 06-25-2003 | 02:31 PM
Dewey316's Avatar
Car: 1990 Camaro RS
ok called the dealer back...
they show white as 19 tooth? a assume that is what you meant, or they are showing it wrong, because the next one they have is 22 teeth.
of course they don't have them in stock , guess i will have to call around more.
Old 06-25-2003 | 02:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have had a couple of them laying around that are white with various other tooth counts besides 19 (which is the right one for 3.73s) for VSS applications; however, the ones for cable applications are typically red.
Make sure your dealer person is looking up the right one for a VSS car. Have him look up something like a 91 Formula LB9 5-speed with G92, which will give you the 3.42 rear gear. Stay away from looking it up for Camaros because they used a cable system for many more years.
This is assuming that you have the VSS in the trans, not a cable to the dash and the VSS behind the cluster.
Old 06-25-2003 | 03:11 PM
Dewey316's Avatar
Car: 1990 Camaro RS
yes i have the vss in the trans.
what i can't figure out it, he found the purple 7tooth just fine, but the white that went with it, showed as 19tooth???
Old 06-25-2003 | 03:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Maybe the others are discontinued.
You need a 20-tooth; as long as you can find a 20-tooth gear that will work with the 7-tooth drive, don't worry about the color. The VSS is color-blind.
jklein337
09-19-2018 07:23 PM
jbd1969
08-17-2015 08:06 PM
mizz0313
08-12-2015 07:45 AM
