82 camaro t56
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
82 camaro t56
I got two ?'s. 1. can you put a t56 in a 82 camaro? 2. Will the stock t56 with stand a 500 hp/ 500 tq 406 motor? Thanks for all the help!
Car: 83Z28 HO
Transmission: G Force 5 speed
Wow.....that's quite a bit of torque!!! :hail:
No, I'm no expert, but I think I read somewhere that even a LS1 T-56 is only rated at like 450 ft. lbs torque, and somthin like 450 HP. The LT1 version slightly less. And the LT1 version is the easier swap of the two.
And BTW - Yes, a T-56 will swap into your 82. Do a search. Lots of good info in there!
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
You will need a driveshaft+torque arm. With that much power, I would have a steel one made. Spohn at the top of the page can help with both.
If your going to use all 500 ponies, the tranny will eventually break. I would get an aftermarket one.
Car: 83Z28 HO
Wow!!..... Do they have a steel fork to fit a T-5???
I'd definatley be interested in getting one if it would allow my T-5 to handle an extra 100 ft. lbs. of torque!!!
Car: 83Z28 HO
Yes you're right. Two different tranny's I know. How does the fork allow the tranny to handle more torque???
I always thought the fork just held the throwout bearing and engages/disengages the clutch??? Just curious i guess. Thanks.
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Even if you did get a stronger case for the T-5, their are still many other weak points in the tranny.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
are their any other differences in the viper t-56's? such as length or anything?
1 Post
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
From what I hear, the input shaft on the Viper is also different: Larger with more splines.
BTW, I'm doing the T56 swap in my '84 right now... I just shut off the garage lights, and there's tools laying all over the place. The T56 is only half an inch from home, but it got stuck. I guess I'll have to back it up and check that pilot bearing.
Car: 83Z28 HO
Supposedly, they shipped out my G Force T-5 yesterday. Said they'd have it finished and shipped "Mid-week" whatever that means. I assume Wednsday.
I dread the install. I'm gettin too old for this.
Car: 83Z28 HO
Originally posted by DABE
let us know how the g force is...im thinking bout getting it and wanted to see what yall say about it....
1 Post
Of course, until I get a ZZ4 crate put in, I only have my lowly L69 to test it with.
1992 Trans Am
08-08-2015 08:16 PM
