*CABLE-X* Installed w/T56--- I LOVE IT!
I just got my Cable-X installed, and it works great. It seems to be very accurate, and is very easy to install and setup. Abbott Enterprises has great tech. support also. I posted here b/c anyone doing a T-56 swap that has a cable drive speedo should definately get one. The car runs much better with the speedo hooked up.
Car: 1991 Camaro RS
Engine: 305 TBI
im confused on how it makes it run better, im in the oppisite situation that your in i have a cable driven tranny and need a setup for electronic speedo.
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
you can have it converted from mechanical to electric I believe. I've heard about it but never saw a product for it.
what do you mean it runs better? what is different. i wonder if that could help some of my little issues.
Firebird355 im confused on how it makes it run better, im in the oppisite situation that your in i have a cable driven tranny and need a setup for electronic speedo
Car: 1982 Trans Am, Black & Gold
Engine: 305 LG4
Transmission: T56 6-Speed
Please help: Cable-X electrical hookup
StocRoc (or anyone else in-the-know),
I'm trying to install my Cable-X box now that I've completed the T-56 swap. I'd like some advice on connecting to the 2-pin VSS connector from the side of the tranny to the Cable-X box.
Q1: Where do the 2 wires from the VSS connector on the tranny connect? Is one of them ground and the other the signal?
Q2: Which one is which, or does it matter?
Q3: The manual indicates that one line is powered (purple) and goes to the ECM, but I'm driving an '82 T/A w/ no ECM input and no VSS buffer box. I simply bought the connector from the dealer for the VSS output at the tailshaft of the tranny, and it has two flying leads. Therefore I suspect I DON'T power either of the two lines to the VSS connector, correct?
Q4: I see in the Cable-X wiring diagram that the ground must be common w/ the VSS sensor and then the signal output from the VSS sensor connects into the Cable-X white wire. But, if I don't apply any power to the VSS sensor, does it still trigger pulses out on the white wire?
Thanks in advance for any words of wisdom. I'm anxious to get the speedo working so I can get the emissions test done.
Thanks!
--Mike
Thanks!
--Mike
Where in Kansas you from StocRoc? I too used a cable x box on my 88 iroc that has a t56 in it. I didn't have drivability problems as far as it dying, but I did have that annoying ses light on all the time and it did seem to run better in general after I got the speedo working.
The cable x boxes are about $350 IIRC. Its just a simple 3 wire operation. Power, ground and something else I do believe, I don't remember wiring it to the ecm at all, I could be wrong though, its been awhile.
56, abbot, abbott, box, cable, cablex, connecting, enterprises, enterprizes, gen, install, installing, problems, speedo, t56, wiring
