rear end whine on a 9bolt B&W
I have a high low whine that seems to be getting worst, it only happen under coast going down hill or coming off throttle. This seems to be a common problem with the BW is there a fix?
yes I did a search but did find a answer to my question
OK Miles
Originally posted by 88 427 Camaro
Most likely pinion bearing preload is too little.
Miles
Miles
thanks for the input
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Yes, special tools are needed. To properly set the pinion preload, the carrier must be removed. You can try just tightening the pinion nut, but you will never know how much preload is on the bearings. Too much and they'll burn out, too little and you have the same problem (which can lead to gear failure or worse).
Miles
Miles
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Just tighten the pinion nut back up. Mine is making noise now, but I've been beating on it with et streets.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The torque is setting by measuring the rotating torque of the pinion when seated in the bearings, not by the torque on the pinion nut. That's why the carrier has to be removed to properly set it up. When you tighten the pinion nut, put some loctite on it.
Miles
Miles
you can always try a fluid change first. When I bought my GTA there was a rear end whine and a leaky diff cover. Only a very small amount of fluid came out when I pulled the cover. I put new fluid in, and within a couple weeks my whine disappeared and has been gone since.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
CW, indirectly it is vibration (loosely stated), directly, it's anything from not enough preload, to embedding, to thread relaxation, to thermal variations to...... One of (if not the best) methods to prevent fasteners from loosening is to use a chemical bond on the joint ie a Loctite or similar. One of the worst methods to use is a split lock washer.
Miles
Miles
$hit miles I hate to do this but
since I cant set bearing preload, what would be your BEST educated guess once the pinion nut is tight, 1/4 1/2 full turn more. I dont want to smoke the pinion bearing but I didnt like the alternative problem
Thanks for the education
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
May also check the teeth on the ring and pinion, I had the same symptoms, and i had a broken tooth on the pinion.
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
