5000RPM stall too big?
Old 05-17-2003 | 09:55 PM
gtabadboy's Avatar
I am getting a TH400 built right now because my 700R4 blew the other week. Its gonna be a full manual valve body, reverse pattern. The stall is from JW converters and will have antibalooning nitrous plates to withstand the 300P shot I have. The guy building the stall said it will be a 5000RPM stall. This seems high to me. My cam says from 3000-7500 I believe and I have the Vic. Jr. intake. Its a lunati hydraulic roller. More specs in sig.
Old 05-18-2003 | 01:09 AM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
5000 sure sounds high to me too
Old 05-18-2003 | 02:16 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I hope this is going to be put on a strip only car because driving in on the street will be PITA. The cops will love you because everytime you take off from a light it will sound like you are racing off the light. The 4.11 gears will tighten it up a little but it is still going to be really loose. With your setup I would think 4000 would be about right. Do you know what RPM your torque peaks out at? If so, take 400-600 from that. That would be a good stall.
Old 05-18-2003 | 09:40 AM
92camaro's Avatar
Did he say if that was the stall with the nitrous or on the motor. If it's the motor the convertor needs to be tighter. Nitrous changed the stall a great deal and you are sparying a pretty big shot. JW is a very good company and I would trust them. But I might call them back just to make sure they know you are using nitrous.
Old 05-18-2003 | 07:48 PM
gtabadboy's Avatar
I am going to use the nitrous and JW is well aware of the 300RWHP shot.
I drive the streets too. As far as I can remember, I think I make max HP and torque over 5300RPM (from Desktop Dyno). This guy is supposed to be one of the best for converters but you really never know. It's pretty much too late to turn back. Its being built or shipped now. So I guess Im stuck to find out.
Old 05-18-2003 | 08:06 PM
gtabadboy's Avatar
Go here for my dyno sheet courtesy of DDYNO. Look for posts concerning gtabadboy. I guess My max HP is at 6000RPM.
DYNO
Old 05-18-2003 | 08:16 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
your gonna rev it to 7,500 with a hydrualic roller?
what are the spring specs and how for past lash are you turing?
IMO for those rpm's id be all over a solid roller
Old 05-18-2003 | 08:23 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
ohhh and 4000 will be good...
Old 05-18-2003 | 09:40 PM
gtabadboy's Avatar
I dont really understand your question. The guy who built the motor used the best of everything except for the heads (Aluminum Dart pr 1s). He said the motor will make power past 7000 RPM, so I am assuming that he would build the motor to withstand RPMs past 7000. He also offers a lifetime labor warantee. I may be completely wrong but I believe the car should be fine at 7000-7500RPM range. The springs are heavy duty and the heads were bought bare. The pushrods are nitrided and all can withstand nitrous at 300HP.
Old 05-18-2003 | 10:26 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
5000 sounds about right for your setup.
It's only a little bit higher than my friends stall in his 98 Z. He is running a yank 4600 stall.
Oh, and it's as bad as it sounds.
Old 05-19-2003 | 01:59 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I stand corrected. That is a pretty BA ride you got. Your torque peak is at 5000. I would suggest 4400 - 4600. The 5000 is going to be really loose but should still work okay. You will still be reving the engine to pull from the light though. It shouldn't be too bad. You will probably have to rev it to about 1500 to get it to move from a stop.
Grant2k
04-04-2016 09:21 AM
cheesehomer
12-31-2015 09:48 AM
SRKLEGIN
10-29-2015 07:38 PM
lanceflame44
09-25-2015 01:28 PM
amcnellis
09-16-2015 05:16 PM
